View information about BGPv6 neighbors.
The following examples shows the summary output for bgp ipv6 neighbors command, and the advertised-routes and routes variable options.
Switch:1>show bgp ipv6 neighbors vrf vrf1 ===================================================================================== BGPv6 Neighbor Info - VRF vrf1 ===================================================================================== BGPv6 neighbor is 2015:cdba:0:0:0:0:3257:9652 remote AS 200, External Peer, BGP state [Established] UP Time 0 day(s), 00:50:30 remote router ID 0.0.0.6 vrf instance - 0 admin-state - BGP ON connect-retry-interval - 120 ebgp-multihop - disable hold-time - 180 keepalive-time - 60 hold-time-configured - 180 keepalive-time-configured - 60 ipv6-max-prefix - 8000 nexthop-self - disable originate-defv6-route - disable neighbor-debug - all remove-private-as - disable route-advertisement-interval - 5 route-reflector-client - disable send-community - disable soft-reconfiguration-in - enable updt-source-interface - 0:0:0:0:0:0:0:0 weight - 100 IPv6Route Policy In - IPv6Route Policy Out - address-family ipv6 - enable route-refresh - enable Total bgpv6 neighbors: 1
Switch:1>show bgp ipv6 neighbors 2015:cdba:0:0:0:0:3257:9655 advertised-routes vrf vrf1 ------------------------------------------------------------------------- The total number of routes advertised to the neighbor is 2 ================================================================================================= BGPv6 Neighbor Advertised Routes - VRF vrf1 ================================================================================================= NETWORK/MASK NEXTHOP ADDRESS LOC PREF ORG STATUS ------------------------------------------------------------------------------------------------- 2001:cdba:0:0:0:0:0:0/64 2001:cdba:0:0:0:0:3257:9651 100 INC Best 2007:cdba:0:0:0:0:0:0/64 2001:cdba:0:0:0:0:3257:9651 100 INC Used -------------------------------------------------------------------------------------------------
Switch:1>show bgp ipv6 neighbors 2015:cdba:0:0:0:0:3257:9655 routes vrf vrf1 ------------------------------------------------------------------------------------------------- The total number of accepted routes from the neighbor is 2 ================================================================================================= BGPv6 Neighbor Routes - VRF vrf1 ================================================================================================= NETWORK/MASK PEER-REM-ADDR NEXTHOP-ADDRESS ORG LOC-PREF STATUS ------------------------------------------------------------------------------------------------- 1100:0:0:0:0:0:0:0/64 2015:cdba:0:0:0:0:3257:9655 2015:cdba:0:0:0:0:3257:9655 INC 100 Used AS_PATH:(150) 2015:cdba:0:0:0:0:0:0/64 2015:cdba:0:0:0:0:3257:9655 2015:cdba:0:0:0:0:3257:9655 INC 100 Best AS_PATH:(150) -------------------------------------------------------------------------------------------------
The following table defines parameters for the show bgp ipv6 neighbors command.
Variable |
Value |
WORD<1–256> |
Specifies the IPv6 address. |
advertised-routes |
Specifies an IPv6 neighbors advertised routes. |
routes |
Specifies an IPv6 neighbors routes. |
WORD<1–256> |
Specifies an IPv6 address/length. |
longer-prefixes |
Shows long prefixes. The longer-prefixes indicate the mask length from any specified prefix to 128. For example, show from prefix :X::X:X/len to X:X::X:X/ 128. |
community <enable|disable> |
Enables or disables the display of community attributes. |
vrf |
Specifies a VRF instance by name (the string length ranges from 1–16 characters). |
vrfids |
Specifies a range of VRFs by ID number (the ID ranges from 0–255). |
